2000 Hyundai Sonata Cooling Fan
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHN LEOS
The cooling fan behind the radiator on the drivers side is not working. Is it possible to replace only the fan motor and not the whole housing? Can the fan motor/housing be replaced by a do-it-yourselfer? how long would a repair like this take? Can anyone recommend a good Sonata shop manual?
Jul 3, 2008 at 4:10 AM
MERLIN2021
  • 17,250 POSTS
Have you tested the fan motor? Unplug the connector and run a power and ground from the battery touch the fan leads, does it start?
Go online to hyundai and you can sign up for online maual for free..
Jul 3, 2008 at 4:40 AM
