2000 Hyundai Sonata Blower Cuts Out
80,000 MILES • 6 CYL • FWD • AUTOMATIC
JEFFTO
My air cond./heater blower is intermittent. In the morning when it's cool, it works fine. If I stop at a gas station and start up again, it no longer works. On a hot afternoon coming out of work it won't work. The air cond. compressor comes on and the switch works fine when the blower is on. Help.
Thanks
Jun 26, 2008 at 10:41 AM
KHLOW2008
  • 41,812 POSTS
Hi JeffTo,
Does the compressor work when the blower is not?
Most probably the blower motor is taking its last breath soon.
When the blower stops working, give it a few knocks and if it works, change it.
Jun 28, 2008 at 4:05 AM
JEFFTO
[quote:993aae8a06="KHLow2008"]Hi JeffTo,
When the blower stops working, give it a few knocks and if it works, change it.[/quote:993aae8a06]
Thanks! Yes the compressor works. How do I access the blower motor?
Jeff
Jun 28, 2008 at 4:25 AM
KHLOW2008
  • 41,812 POSTS
Hi JeffTo,
Since the compressor works, we can safely say the blower needs to be replaced.
The blower is underdash on passenger side and you don't need to get to it directly. Just reach under the dash and give the plastic housing some banging with your hands. You hve to remove the cover if there is any.
Jun 28, 2008 at 1:37 PM
