1999 Hyundai Sonata Nothing
250,000 MILES • 6 CYL • FWD • AUTOMATIC
SPAR
My Sonata when you put it in drive or reverse there is nothing, most of the time. Sometimes it works for a while and then it seams like the transmission goes to netural, and no gears work. I have to keep shutting off the engine and starting it back up for the transmission to work again, and it only works for a short period. I have changed the transmission oil and filter but to no avail. Can anyone help me with this please. Thanks
Nov 5, 2008 at 10:26 AM
  • 31,937 POSTS
Hi there,
As you have already done what you can, there is no option but to seek the advice of a transmission specialist, there will be a few tests that they can do, to determine the exact cause of you problem, there is nothing that you can do your self with out some test equipment.
mark (mhpautos)
Nov 7, 2008 at 8:29 PM
