1999 Hyundai Sonata
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
RODRIJESUS
i change the termostat, mi car runing litte time in come in over heat
Aug 24, 2009 at 10:46 AM
  • 31,937 POSTS
Hi there,
Check that the pressure cap is holding pressure ok, check for any external coolant leaks with a system pressure test, are the fans coming on when it get hot? have the radiator cleaned & flow tested, if all is ok have a head check done for Co in the cooling system as this will be an indication of a head gasket problem, start here.
mark (mhpautos)
Aug 24, 2009 at 10:50 AM
