1997 Hyundai Sonata cut off while driving
HARDYASHC
  • 1997 HYUNDAI SONATA
1997 Hyundai Sonata Front Wheel Drive Automatic 145000 miles
my car cut off while driving, never did it before and won't start back up.
Tuesday, June 1st, 2010 AT 4:09 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tuesday, June 1st, 2010 AT 4:37 PM
