1996 Hyundai Sonata Sonata injectors
CRAZYMAN2004
Computer problem
1996 Hyundai Sonata Manual
Hi I have a 1996 Sonata. The fuel injectors on the car is not working - there's no problem with the fuel pump. What can cause the problem ? Can it be computer not sending signal ? What else is involved with sending signal to injectors ? Thank you
Sep 5, 2010 at 7:39 PM
  • 31,937 POSTS
Hi there,
cam & crank angle sensors are involved it setting the correct firing of the injectors, but it there is a problem here you will normally get a fault code, if no light is showing, i would still do a scan and check for any unresolved fault codes also check for a blown main EFI fuse.
mark (mhpautos)
Sep 5, 2010 at 8:57 PM
