1995 Hyundai Sonata engine replacement
DOUBLEWIDEEXPRESS
Engine Mechanical problem
1995 Hyundai Sonata 4 cyl Front Wheel Drive Automatic
i was wondering if any other block could be made to fit a 95 hyundai sonata 2.0 dohc engine mine is automatic and the timing belt broke and dropped 2 valves and busted 2 pistons i have been told an older eagle talon block are plymouth laser block would fit but other have said only a 95 hyundai sonata block will fit the blocks on a older eclipse 2.0 dohc cam look like they would work any help would be great thanks
Mar 27, 2009 at 8:32 AM
ZACKMAN
  • 4,202 POSTS
If you want to do drop in (plug and play) engine replacement, you can only use 1995 - 1996 engine Sirius 1997cc. No other engine will drop in. Not even the new Hyundai-built 2.0L meant for Tiburon/Elantra models.
While 4G63 Mitsu motor "looks" similar and will fit the engine bay, it NOT plug and play. I am not even sure if the transmission will bolt onto the engine. And you will have to retrofit the location for the engine mounts.
Mar 29, 2009 at 12:47 PM
DOUBLEWIDEEXPRESS
thanks so much for the reply it was very handy and saved me alot of work
Mar 29, 2009 at 3:23 PM
ZACKMAN
  • 4,202 POSTS
You are welcome.
Mar 30, 2009 at 2:38 PM
