1993 Hyundai Scoupe
1993 HYUNDAI SCOUPE
MATTYO61
Electrical problem
1993 Hyundai Scoupe 4 cyl Front Wheel Drive Manual 223000 km
I recently had the computer changed in the car and since getting the car back the check engine light is permanently on, The car if it sits for about a month without starting will drive fine but the more i drive the more the car will stall, choke with a rough idle. Please help. I have changed the petral filter, leads plugs air filter with no change. Any ideas.
Matt
Nov 29, 2009 at 6:03 PM
  • 31,937 POSTS
Hi there,
The check light is indicating a stored fault code in the ECU. You will have to get a scan to read this code, it will give you an indication as to where the main fault lies with this problem, start here.
mark (mhpautos)
Nov 29, 2009 at 6:40 PM
