2002 Hyundai Santro engine failures
40,246 MILES • 4 CYL • 2WD • MANUAL
MOHAMALA_RAGHAVA
while driving in hot sun and in heavy traffic when i have to use the clutch and brake repeatedly, the engine goes off by itself while on the run. i get a feel like the vehicle is going to stop. this problem aggravates when the AC is used again with switching on and off depending on the need. when i need compression, i am having to switch the AC off. I gave the car with this complaint to Huyandi service station in hyderabad, Kushaguda unit, twice. The problem could not be identified. The problem is not faced with in the mornings or evening when it is cool. Something to do with external temp conditions. what this could be. can you please enlighten in the light of the routines you perform on vehicles all the time. Will anxiously await your tips. thanks in advance.
raghava.
Apr 17, 2009 at 5:58 PM
PRASHANT
may be the fuel pump motor need to be replaced,loose clutch or its just the bad fuel quality.
May 31, 2009 at 7:11 PM
