2007 Hyundai Santa Fe rear lights will not go off
30,500 MILES • 6 CYL • 2WD • AUTOMATIC
BOBROADCAP
the stop/tail & high-mounted rear stop light will not go off even after the car has been turned off. I am trying to figure out how to get them to turn off.
Aug 24, 2008 at 2:11 PM
  • 75,989 POSTS
Find the brake switch follow the brake pedal arm till it meets with the support bracket- disconnect the connector for the switch and see what happens to the light-if it goes off-adjust the switch or replace it.
Aug 24, 2008 at 2:28 PM
