purge control valve solenoid
JTB224
Engine Performance problem Fe 6 cyl Two Wheel Drive Automatic
2007 santa fe 2.7 v6-where is the purge valve solenoid located , thanks
Apr 26, 2010 at 1:32 PM
  • 55,554 POSTS
The EVAP system purge solenoid is located near the mass air flow sensor. Here are some diagrams to help you find it (below)
Please let us know if you need anything else to get the problem fixed. These are for both engine BTW
Cheers, Ken
Sep 15, 2017 at 10:13 AM
