2004 Hyundai Santa Fe no spark
2004 HYUNDAI SANTA FE
ROBERTJ0929
  • 5 POSTS
Electrical problem
2004 Hyundai Santa Fe 4 cyl Two Wheel Drive Automatic
I replaced the fuel pump and the cam sensor ond the car will turn over but will not start . what could be the problem?
Jul 11, 2010 at 2:49 AM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 11, 2010 at 12:07 PM
