2004 Hyundai Santa Fe 6 cyl Automatic 117000 miles
My cruise control was working fine until today. The light comes on but it will not engage.
Any help would be great!
Thank you!
Louise
SPONSORED LINKS
Wednesday, March 31st, 2010 AT 7:27 PM
BLUELIGHTNIN6
MECHANIC
Check #4 (10 amp), # 14 (10 amp) and # 19 (10 amp) fuses in the passenger compartment relay box. Also check ECU #3 (10 amp) fuse in the engine compartment relay box. If all OK, check to ensure the horn sounds. If OK there as well, see if the tachometer is working properly. Let me know how these check out.
SPONSORED LINKS
Wednesday, March 31st, 2010 AT 9:33 PM
LOUISEHARRIS
MEMBER
I have checked the fuses above and the horn is working, (I do not know how to check the tachometer.) But the Cruise Control is still not working.
Thanks,
Louise
Friday, April 2nd, 2010 AT 5:39 PM
BLUELIGHTNIN6
MECHANIC
Ok if all is good there then you have a faulty cruise control unit.
