CAR WAS IN COLLISION FRONT END PUT BACK TOGETHER BUT RUNS ROUGH WONT IDLE
HAS A CODE OF P 1193
Jun 10, 2010 at 8:27 AM
BLUELIGHTNIN6
✓Experienced Mechanic
Hello and thanks for donating
DTC P1193 - Limp-Home Mode -- Low RPM
This indicates that the vehicle's engine speed has dropped below 470 RPM. You will need to check all components that may cause engine stalling / low idle. This could be weak spark plugs, bad plug wires, low fuel pressure, etc...
