2004 Hyundai Santa Fe CODE P1193
2004 HYUNDAI SANTA FE
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
RICKJSALYER
CAR WAS IN COLLISION FRONT END PUT BACK TOGETHER BUT RUNS ROUGH WONT IDLE
HAS A CODE OF P 1193
Jun 10, 2010 at 8:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
DTC P1193 - Limp-Home Mode -- Low RPM
This indicates that the vehicle's engine speed has dropped below 470 RPM. You will need to check all components that may cause engine stalling / low idle. This could be weak spark plugs, bad plug wires, low fuel pressure, etc...
Jun 10, 2010 at 1:44 PM
