hyundai santa fe 2003 - weird noise
161 MILES • 2.7L • V6 • AUTOMATIC
RODRIGOGSI
  • 6 POSTS
WEIRD INTERMITTENT NOISE WHEN STOPPED ON A RED LIGHT ON DRIVE WITH BREAKS ON AND THEN PUT GAZ AND IT GOES INTO THE FIRST D - DOES NOT HAPPENDS ALL THE TIME - DONT KNOW IF IT IS A TRANSMISSION NOISE OR BREAKS STUCK ? ANY HELP WILL BE
here is a video of the sound that my car is making
Sep 10, 2014 at 3:51 AM
RODRIGOGSI
  • 6 POSTS
getting worried . no answers yet :( hope you can identify the noise
thanks again
Sep 10, 2014 at 5:47 AM
RODRIGOGSI
  • 6 POSTS
Its the breaks getting stuck?
Sep 10, 2014 at 9:38 AM
  • 110,248 POSTS
The link you provided doesn't work.
Sep 10, 2014 at 10:31 AM
RODRIGOGSI
  • 6 POSTS
Sorry for that
can you please try this one ....
you will hear the noise almost in the beginning of this video ..
sounds a bit like a rusty door opening - looks like it is my breaks that get stuck ... but not 100 % sure.... like I said previously - it does not happends everytime ... looks more before I press the break for a long time ... or something ...
this one should work ..
http://youtu.be/m9IPisD-SUw
Sep 11, 2014 at 1:02 AM
  • 110,248 POSTS
I did hear it. Does the noise happen when you are stopped or as you are stopping? Listening to the video, it sounds like a rubber bushing.
Sep 11, 2014 at 11:11 AM
RODRIGOGSI
  • 6 POSTS
When u press the gaz . After a red light . Or when u press the breaks to change from P to D
Sep 12, 2014 at 5:28 AM
RODRIGOGSI
  • 6 POSTS
Looks like it is after using the breaks
Sep 12, 2014 at 5:29 AM
  • 110,248 POSTS
I can't for sure from the video, but I think the first things you should check are rubber bushings, motor mounts, and struts / strut mounts.
Sep 12, 2014 at 11:58 AM
RODRIGOGSI
  • 6 POSTS
hi again ... can you verify the noise again
I did a test and I used my manual shifter to go from 1st shift to second and come back to first and the sound came from the first gear
sounds more and more as a transmission issue ... what do you think ?
could be wrong I am not a mechanic at all
but testing it .... looks like ...
Sep 22, 2014 at 5:38 AM
  • 110,248 POSTS
It is so hard to tell listening through cheap speakers on a computer. It still sounds like a bushing. Check trans and motor mounts.
Sep 22, 2014 at 10:29 AM
