2003 Hyundai Santa Fe Water Pump
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
SUPTCCOX
Where is the water pump located on the engine and how do you replace it?
Feb 21, 2010 at 12:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is this for the 2.7L or 3.5L engine?
Feb 21, 2010 at 1:02 PM
SUPTCCOX
The Santa Fe in question is a 2.7 L V6.
Feb 21, 2010 at 11:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Drain the cooling system. Remove or disconnect the following: Negative battery cable Drive belt and water pump pulley Timing belt covers Timing belt tensioner Idler pulley Water pump bolts Water pump and gasket Clean the gasket mating surfaces.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1728.jpg
Install or connect the following: Water pump and gasket Bolts and alternator bracket. Tighten the bolts to 11-16 ft. lbs. (15-22 Nm). Idler pulley Timing belt tensioner Timing belt covers Water pump pulley and drive belt Negative battery cable Fill the cooling system. Start the engine and check for leaks.
Feb 22, 2010 at 2:31 AM
