2003 Hyundai Santa Fe ticking noise in top rear engine
2003 HYUNDAI SANTA FE
72,000 MILES • 6 CYL • AWD • AUTOMATIC
TIMSCHEVROLET
  • 7 POSTS
Just replaced my worn out engine with a used one with 72000 miles. Had a vacuum leak but fixed it, now the truck runs great but there is a ticking noise from the rear top of the engine (lifter?). I heard that aftermarket oil filters restict oil flow ? What oil viscocity to use. Can someone help !!!
Feb 21, 2010 at 1:48 PM
  • 110,244 POSTS
It does sound like a lifter. As far as the oil filter, any name brand filter is fine to use. They won't restrict oil flow. I looked up the recommend oil. If you have the 2.7 and it is from an 2003, mitchelle online lists 10W30.
May 22, 2010 at 6:14 PM
