2003 Hyundai Santa Fe splitting trans from engine
172,000 MILES • 6 CYL • AWD • AUTOMATIC
TIMSCHEVROLET
  • 7 POSTS
I am replacing the engine in my 03 Santa Fe. I want to leave the trans in the vehicle. I unbolted the the trans from the engine, unbolted the plate from the flywheel. I tried to use a gasket scraper and a hammer to split the two but it doesnt budge. Hopefully someone can help
Jan 30, 2010 at 5:14 AM
  • 110,248 POSTS
Are you sure all of the bolts are removed? Also, there are guide pins between them. If they are not straight, they may be on a bind causing the problem.
Feb 6, 2010 at 1:24 PM
