2003 Hyundai Santa Fe OBD11 Code P0421
72,000 MILES • 4 CYL • 2WD • AUTOMATIC
DALE BLACKWELL
OBD Code Po421
Changed the catalytic converter recently.
Engine would hardly go over 15 mph.
Repaired broken valve #2 cylinder.
New valve job.
New rebuilt transmission.
Suspect Vacuum leak or oxygen sensor
Jul 13, 2008 at 9:09 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:423a209e86="Dale Blackwell"]Computer problem
2003 Hyundai Santa Fe 4 cyl Two Wheel Drive Automatic 72000 miles
OBD Code Po421
New valve job.
Suspect Vacuum leak or oxygen sensor[/quote:423a209e86]
Ok, so vehicle is running fine now and only need info on code?
Code Definition:
P0421 - Warm Up Catalyst Efficiency Below Threshold
Jul 13, 2008 at 11:18 AM
