2003 Hyundai Santa Fe Harmonic Balancer
2003 HYUNDAI SANTA FE
RONTHEJEDI
Drive Train Axles Bearings problem
2003 Hyundai Santa Fe 4 cyl All Wheel Drive Automatic
I took my wife’s 2003 Hyundai Santa Fe over 100K miles, in for what appeared to be a blown power steering pump. The mechanics diagnosed it as a problem with the harmonic balancer between the crankshaft and motor. As it was explained to me the harmonic balancer maintains the balance between the tires, crank, motor and transmission. The mechanic also explained they that needed to remove the balancer to check the key and crank shaft to ensure that they were not damaged. I left the vehicle to be inspected, an hr later I get a call stating that the crank shaft had fallen off the car and needed to be replaced. Along with the timing belt, water pump and various other things?
I’ve never heard of a crank shaft just falling off a car, my questions are?
What could have caused the crank shaft to fall off the car?
Could the mechanics had failed in following the proper techniques to inspect the crank shaft and ensuring that no further damage was down to the car?
Are there any other common problems I could have with this car in the future?
Mar 16, 2010 at 12:13 AM
2CARPRO JACK
  • 11,533 POSTS
I have never heard of a crankshaft "falling off" before.The only thing that comes to mind is that the crank broke where the balancer mounts.I looked in the TSB's (Tech Service Bulletins) and didnt see anything related to crankshaft problems except an updated torque spec for the bolt that holds the balancer on.You may want to go down there and look to see what happened, this may help with explaining what went wrong.There are a few TSB's for this vehicle, but nothing more than any other out there, I wouldnt worry about other issues with it, but this one has me curious. What was the initial reason for taking it in?
Mar 16, 2010 at 1:11 AM
RONTHEJEDI
The car became difficult to turn at low speeds. Then one day it became almost impossible to turn the steering wheel. I initially thought it was the powersteering pump.
Mar 16, 2010 at 1:46 AM
2CARPRO JACK
  • 11,533 POSTS
Was the alt (Charge) light on? If it was an issue with the crank snout or key being broken and not turning the alt wouldnt be charging either
Mar 17, 2010 at 12:50 AM
