2003 Hyundai Santa Fe 03 santa fe idles high when in park
116,073 MILES • 6 CYL • 4WD • MANUAL
HYUNDAIGIRL
I replace the ingition wires and spark plugs after getting these replace my truck started cutting off when I press my brakes or a hard turn the mechanic said he will adjust the idle and now its idles when the truck is not motion and the truck is riding ruff instead a smooth ride like it used what can I do or what did he do wrong so i can find someone to fix the problem
Jan 8, 2010 at 1:19 PM
BLACKOP555
  • 10,386 POSTS
are the wires routed properly?
did you change one plug and wire at a time?
also did you use replacement plugs of the same plug number and also gapped to what is listed on the vehicle emission laable underhood?
Jan 9, 2010 at 2:22 AM
