The Right front shakes when I hit the brakes?
2002 HYUNDAI SANTA FE
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
NISHU85
Whenever i take out my car on highway and exceed 60mph, the right front starts to shake in a clocking manner when I am on the brakes. I just had my wheels aligned and that also doesn't help. The shaking only happens on right front.Thanks a lot for any help. Nishant
Dec 29, 2009 at 3:40 AM
SQM
  • 6,383 POSTS
First item should be checked is your tire. Make sure it is balanced and does not have any type of flat spots.
If a tire is out of balance it can vibrate at higher speed.
Have the tire balance checked as well as look for flat or uneven spot on the tires.
https://www.2carpros.com/articles/how-car-tires-work
Also a worn control arm bushing can cause vibration.
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
This can also happen for having wrapped brake rotors.
Aug 1, 2021 at 12:53 PM
