2002 Hyundai Santa Fe Rear End Noise
115,000 MILES • 6 CYL • AWD • AUTOMATIC
ZACHISHI
I have the same problem as the other poster and i didn't see a response.
Here are the simptoms:
-Rolling at idle speed or just above there is a rubbing noise that seems to be coming from the left rear tire. Once I noticed it I replaced all rotors and pads, front and rear. It needed it anyways. Noise stayed
-Noise seems to stop if I touch the brakes.
-Noise has gotten progressively loader
-I replaced all tires and had an alignment, noise stayed
-Rear CV joint seems to be intact and in good running order by appearance.(no cracked boots, not broken seals. Feels firm)
-Tested rear caliper by taking it off the rotor and pressing the brake, It seemed to compress normally.
-I am also hearing a lot of squilling from the rear brakes, they are still very new. I cant seem to get rid of it.
I have done the same basic things and no change. Please let e know. Thanks Zach
Feb 29, 2008 at 11:43 PM
BONZLY
I have a similar problem except mine is a high pitch noise that happens after I have driven for 10-15 minutes and then stops when I hit the brakes. Appears to be coming from rear brakes or just rear of car. I have not done anything except have mech look at it and listen for noise. Have you tried asking this question of someone at the dealership?
Apr 19, 2008 at 9:34 AM
BEEJAYLOUISE
The Santa Fe has two sizes of rear brake shoes. One is slightly wider than the other, but will fit. Generally the issue is the wrong shoe has been installed. check to see if this is the case with yours.
Oct 5, 2012 at 10:54 AM
