2002 Hyundai Santa Fe power steering failue
2002 HYUNDAI SANTA FE
FRAWES
Steering problem
2002 Hyundai Santa Fe 4 cyl Two Wheel Drive Automatic 116k miles
I replaced a power steering pump on this 2002 santa Fe approx. 15k miles ago. the same problem seems to be happening again. When I replaced the initial pump the splines designed into the pulley and the pump drive shaft had worn smooth. Why is that and what should I do to fix it?
Jun 21, 2009 at 6:41 AM
SERVICE WRITER
  • 9,123 POSTS
I can't tell you why it wore out, but the reservior screens can get plugged on these and burn out a pump. Remove the reservior, remove the screen and clean it Caviitation can also do damage to pumps. USing the best fluid helps. Hyundai semi synthetic ATF is best for this truck.
Jun 21, 2009 at 10:41 AM
