I used to own a 1994 Honda Civic. When the check engine light came on, I could insert a jumper into the scanner plug and the Check Engine light would flash in a series of dots and dashes that I could then identify the diagnostic code. It was a poor man's scanner, if you will.
I now drive a 2002 Hyundai Santa Fe. Is there a similar means to extract the Check Engine diagnostics without having to buy a scanner?
SPONSORED LINKS
Saturday, October 30th, 2010 AT 10:48 PM
