2002 Hyundai Santa Fe Check Engine Light
2002 HYUNDAI SANTA FE
198,000 MILES • 6 CYL • FWD • AUTOMATIC
JANICE TRIPLIN
The check engine light came on. The first thing I did was to check the oil level. It was very low. I added 3 bottles of oil but the light continued to stay on. What else should i check for? Is there a way to reset something so that the light will go out. Thanks!
Aug 27, 2009 at 2:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You will need to retrieve the trouble codes that are stored before you want to delete them. Do this by either purchasing a diagnostic scanner for your vehicle, or have a local auto part store do it for you. Most will scan it for free of charge. Post the code(s) you retrieve and I will follow up.
Aug 27, 2009 at 3:51 PM
