2001 Hyundai Santa Fe turno off, then after 2 hours on
FAREEZAW
Electrical problem
2001 Hyundai Santa Fe 4 cyl Two Wheel Drive Manual
dear all
I have 2001 santa fe.
suddenly it turns off and does not start again but you can hear the starter working good but the motor does not work.
after 2 hours it will start normally.
Some times it turn off after on 2 minutes ( it is cold , not heat problem ).
One electrician checked it and not find problem
pls advise.
Thanks
mfareezaw@yahoo.com
fareez
Nov 11, 2009 at 6:15 PM
BMRFIXIT
  • 19,053 POSTS
Suspect crank position sensor
check for codes and pending codes
check for crank signal as starting
Nov 11, 2009 at 9:55 PM
