2001 Hyundai Santa Fe Hard Shifting when cold
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
TODD3804
I have a question today while driving the car like jumped out of gear like it was in n then slammed into gear and the engine light came on. I have a code reader and pulled the codes. It came up with 4 codes. P1529, P0760, P0755, P0750 I tried to look them up but I don't understand what they mean or what to do to fix it. If you could help me figure out what to do that would be great.
Jan 23, 2010 at 5:13 AM
MATHIASO
  • 1,209 POSTS
Hello todd3804
Welcome to 2carpros.com
Your vehicle is affected in a recall; your vehicle dealer may have sent you a recall notice to rectify the defect, or you may not have received a notification from the motor dealer, then you are advised to contact him . Your motor dealer may not be able to contact you if your address has been changed or the latest ownership of your vehicle is not updated in their records.
Trouble Code: P0760
A/T Second Solenoid Valve Circuit Malfunction
Possible Causes:
2nd solenoid control circuit is open or shorted to ground
2nd solenoid is damaged or has failed
TCM has failed
TSB 00-40-009 (8/00) contains information about this code
Trouble Code: P0755
U/D Solenoid Valve Circuit Malfunction
Possible Causes:
U/D solenoid control circuit is open, shorted to ground or power
U/D pressure switch is open, shorted to ground or it has failed
U/D solenoid is damaged or has failed
TCM has failed or the TCM power ground circuit is open
Trouble Code: P0750
Low/Reverse Solenoid Circuit Malfunction
Possible Causes:
L/R solenoid control circuit is open, shorted to ground or power
L/R pressure switch is open, shorted to ground or it has failed
L/R solenoid is damaged or has failed
TCM power ground circuit is open, or the TCM has failed
Trouble Code: P01529
Customer Snapshot Request Error
Possible Causes:
Transmission control module error
Check for trouble codes in the transmission control module
TSB 1-40-005 (3/01) contains information about this code
Jan 23, 2010 at 12:58 PM
