2001 Hyundai Santa Fe
2001 HYUNDAI SANTA FE
120,841 MILES • 6 CYL • 2WD • AUTOMATIC
JY3K
When driving at a constant speed engine stalls. if you push the accelerator down the engine catches back up and may run fine for a while but normally it does this quite often. Throttle position sensor has been replaced, coils, plugs, plug wires, and all injectors have been replaced. When scanned the only code is the one for random misfire.
Jul 26, 2010 at 10:46 AM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 26, 2010 at 8:56 PM
