starter
HYUNDAI
J.R FARLEY
112,000 on a 98 hyundai accent where is the starter located at i cant seem to find it. Do you have to get under the car or can you take it out from under the hood thanks
Aug 14, 2007 at 7:37 AM
  • 75,988 POSTS
[quote:97471498b9="J.R Farley"]112,000 on a 98 hyundai accent where is the starter located at i cant seem to find it. Do you have to get under the car or can you take it out from under the hood thanks[/quote:97471498b9]
Follow the positive cable towards the engine/tranny once you locate it, disconnect the negative cable -you need to remove the speedometer and shift cable the rest is yours
Aug 14, 2007 at 11:41 AM
