Random start
REGB34
  • HYUNDAI
1999 Tibiron w/ 111500 miles, 5 speed standard with average maintianence over its life. The car rund great and starts 85% of the time, but after long drives or frequent stops and restart it will not start. This first occured over three months ago and did not happen again for over two months. In the past month it has happened more frequently. Of course car shop won't check it out without seeing it when it won't start. Fortunately its a stick so push start and poping the clutch still works.
confused on what to do next?
Sunday, July 22nd, 2007 AT 4:44 AM
CHEVY22
  • 1,375 POSTS
DID YOU REFILL AND BLEED THE CYLINDERS AND REFILL TO PROPER LEVEL
Sunday, July 22nd, 2007 AT 7:29 AM
DBABYN
  • 13 POSTS
Hello, did you remove the ground cable from the battery, before you started the work? The computor has some system always on standby, a low fluid may have taken place. Try removing the ground, turn key on for one minute(no ground), turn off. Leave ground off for about 15min, Key OFF, reconnect ground, the computor will now reset, and it will take about 20 min, of driving before it will be fully reset, after that time frame, is the light still on? If so you me need to have a Diagnostic check done.
Sunday, July 22nd, 2007 AT 1:20 PM
KEVINHEAP
Thanks for the information. I did bleed the system and my level for brake fluid is okay so I will try disconnecting the ground procedure.
Monday, July 23rd, 2007 AT 4:37 AM
