KEYLESS ENTRY
HYUNDAI
JSULI
I HAVE A 2003 HYUNDAI TIBURON WITH A 4 CYL. THE PROBLEM WE HAVE IS WHEN YOU PUSH THE UNLOCK BUTTON THE DOOR LOCKS WILL UNLOCK AS NORMAL THEN INTERMITTENTLY RELOCK ITSELF. SOMETIMES IT WILL EVEN GO THROUGH 2 OR 3 CYCLES OF LOCKING AND UNLOCKING ITSELF. WE HAVE ALREADY HAD THE 1 REMOTE REPROGRAMMED. AND THE OTHER HAS STILL BEEN WORKING FINE(BATTERY WISE). BUT AS FAR AS I CAN TELL THERE IS NO WAY FOR ME TO CHECK THE BCM TO SEE IF THERE IS A CODE UNLESS ITS THROUGH THE DEALERSHIP WHICH HAS ALREADY RIPED MY WIFE OFF TO MANY TIMES. ANY HELP IS APPRECIATED.
THANKS
Nov 19, 2006 at 1:25 PM
SHUGGY
i would suggest one of the door actuators are faulty try turning the key in the lock and you may feel resistance in the mechanism do this on both doors this is quite a common problem on early coupes
Nov 25, 2006 at 1:03 AM
