hyundai verna 2005 engine lamp lighting after 150 km
2005 HYUNDAI
HBORSA
  • 6 POSTS
hi
i ask about verna 2005 the engine lamp is light after 150 km\h what is the reson ???
thnk you
Aug 28, 2007 at 7:23 PM
  • 75,988 POSTS
[quote:fa2124d59a="hborsa"]hi
thnk you[/quote:fa2124d59a]
It means the computer in it has detected a problem and it needs to be scan for code/s which is the starting point for troubleshooting. We need the code/s before we can give an advice.
Aug 28, 2007 at 8:37 PM
HBORSA
  • 6 POSTS
[quote:96756dd177="rasmataz"][quote:96756dd177="hborsa"]hi
thnk you[/quote:96756dd177]
It means the computer in it has detected a problem and it needs to be scan for code/s which is the starting point for troubleshooting. We need the code/s before we can give an advice.[/quote:96756dd177]
on my scan not fault code but i ask if the oxigen sensor o2 cause this problem
and if you have repair manual for hyundai accent ,elntra.verna and sonata i will happy for this
mr rasmataz i want your email if you can
thank you
Aug 29, 2007 at 9:42 PM
  • 75,988 POSTS
[quote:f41f90e089="hborsa"][quote:f41f90e089="rasmataz"][quote:f41f90e089="hborsa"]hi
thnk you[/quote:f41f90e089]
It means the computer in it has detected a problem and it needs to be scan for code/s which is the starting point for troubleshooting. We need the code/s before we can give an advice.[/quote:f41f90e089]
thank you[/quote:f41f90e089]
Just because the light came On-doesn't mean its the O2 sensor, who's been talking to you. You need to scanned the computer for code error. I cannot help without it-
Aug 29, 2007 at 10:09 PM
  • 75,988 POSTS
[quote:016973780b="hborsa"][quote:016973780b="rasmataz"][quote:016973780b="hborsa"]hi
thnk you[/quote:016973780b]
It means the computer in it has detected a problem and it needs to be scan for code/s which is the starting point for troubleshooting. We need the code/s before we can give an advice.[/quote:016973780b]
thank you[/quote:016973780b]
Click manual -under the quote
Aug 29, 2007 at 10:11 PM
