hyundai excel clutch
HYUNDAI
CAMOLIVERPOOL
hyundai excel 1997, when i went to start my car everything was all good, untill i put the clutch down to put in gear it semed to be a lot more stiffer but i could still put it in gear. When i to excell as normal my car stalled. Now my Clutch is very stiff, still moveable, and starts to shake a little when pressed. with clutch in its like its not working, it is like your trying to drive a car without a clutch. wat could be makeing this problem because i can get the parts.. thanks
Apr 19, 2007 at 3:54 PM
  • 75,988 POSTS
[quote:16dd772e0b="camoliverpool"]hyundai excel 1997, when i went to start my car everything was all good, untill i put the clutch down to put in gear it semed to be a lot more stiffer but i could still put it in gear. When i to excell as normal my car stalled. Now my Clutch is very stiff, still moveable, and starts to shake a little when pressed. with clutch in its like its not working, it is like your trying to drive a car without a clutch. wat could be makeing this problem because i can get the parts.. thanks[/quote:16dd772e0b]
Hydraulic or Cable clutch system
Apr 19, 2007 at 6:44 PM
CAMOLIVERPOOL
[quote:c59b60dbf3="rasmataz"][quote:c59b60dbf3="camoliverpool"]hyundai excel 1997, when i went to start my car everything was all good, untill i put the clutch down to put in gear it semed to be a lot more stiffer but i could still put it in gear. When i to excell as normal my car stalled. Now my Clutch is very stiff, still moveable, and starts to shake a little when pressed. with clutch in its like its not working, it is like your trying to drive a car without a clutch. wat could be makeing this problem because i can get the parts.. thanks[/quote:c59b60dbf3]
Hydraulic or Cable clutch system[/quote:c59b60dbf3]
Thanks, but im wondering a can get a brand new clutch kit -plate, cover assembly and bearing. Do you Recon thhis will fix the problem if i machine the flyweel first?
Apr 19, 2007 at 7:05 PM
  • 75,988 POSTS
[quote:f3c22e0c73="camoliverpool"][quote:f3c22e0c73="rasmataz"][quote:f3c22e0c73="camoliverpool"]hyundai excel 1997, when i went to start my car everything was all good, untill i put the clutch down to put in gear it semed to be a lot more stiffer but i could still put it in gear. When i to excell as normal my car stalled. Now my Clutch is very stiff, still moveable, and starts to shake a little when pressed. with clutch in its like its not working, it is like your trying to drive a car without a clutch. wat could be makeing this problem because i can get the parts.. thanks[/quote:f3c22e0c73]
Hydraulic or Cable clutch system[/quote:f3c22e0c73]
Thanks, but im wondering a can get a brand new clutch kit -plate, cover assembly and bearing. Do you Recon thhis will fix the problem if i machine the flyweel first?[/quote:f3c22e0c73]
If you wish have the flywheel resurface and clutch assy replaced. after these-bleed the M/C and the slave if it has one or adjust the cable and its free play.
Apr 19, 2007 at 7:43 PM
