Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Other
Drivetrain
Transmission
Replace/Remove
hyundai elantra trans removal 99
1999 HYUNDAI
BUB CULLETT
MEMBER
trans bolts everythings off mounts starter axls whats in bell houseing holding it and how to disloge it
Mar 25, 2006 at 11:44 AM
PEPPERMRJ
Experienced Mechanic
Did you unbolt the torque convertor from the flywheel?
Mar 25, 2006 at 11:49 AM
BUB CULLETT
MEMBER
its a manual trans
Mar 25, 2006 at 11:57 AM
PEPPERMRJ
Checklist from my book.
negative battery cable
air intake assembly
clutch slave cylinder
speeometer cable
shift cables
starter motor
axle halfshafts
flywheel cover
transaxle mounts
transaxle flange bolts
transaxle
My last car with a clutch was a 1961. Never had a bike without one tho.
I would think it would also have to be in neutral?
Good luck and let us know :)
Mar 25, 2006 at 12:18 PM
BUB CULLETT
MEMBER
you have to take cluch harm off of trans after takeing hyd mec off so through out bearing can release ty i figed it out trans is out
Mar 25, 2006 at 12:40 PM
PEPPERMRJ
Congrats! Thanxs for the update. :)
Mar 25, 2006 at 12:44 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
