fan belt squeling
HYUNDAI
SONATA
Hey just wanted to know how to get rid of some annoying squeling noises comming from the fan/drive belts. I've already tightened the tension of the belt it has made it better but its still there!! What can I do to fix the problem. I drive a hyundai sonata 2000. also the battery wire which drives my stereo is not working. How can I fix this, I checked the fuses but I can't find the problem!! The car has done 150000km. Thanks
Feb 26, 2006 at 12:46 PM
PEPPERMRJ
  • 1,158 POSTS
[quote:a43393fc27="Sonata"]Hey just wanted to know how to get rid of some annoying squeling noises comming from the fan/drive belts. I've already tightened the tension of the belt it has made it better but its still there!! What can I do to fix the problem. I drive a hyundai sonata 2000. also the battery wire which drives my stereo is not working. How can I fix this, I checked the fuses but I can't find the problem!! The car has done 150000km. Thanks[/quote:a43393fc27]
Either replace the belt or pull it off and check all pulleys by spinning them by hand.
Run a new power wire. :)
Good luck and let us know. :?:
Mar 3, 2006 at 9:52 AM
