Excel Overheating
HYUNDAI
RICK269
I have a '95 model Hyundai Excel Twin-Cam which is overheating. I have traced it to the cooling fans not switching on. It has air conditioning and the aux. fan also will not switch on. I believe they operate separately from each other? All the fuses are intact and the wiring looks to be in good order. Problem is I can't find the thermo switch, I am presuming it is separate to the temperature gauge sensor.
Oct 19, 2007 at 9:57 PM
MERLIN2021
  • 17,250 POSTS
When U say "Falls" into neutral, does the shift lever move? Or do you just loose power? If U loose power check fluid level! if thats OK Tranny needs a rebuild...
Aug 7, 2007 at 11:11 AM
BLACKOP555
  • 10,386 POSTS
The is a sensor that senses the coolant then sends it to a sending unit which in turn sends it to the ECM. Find the one and follow the wires to the other.
Oct 20, 2007 at 12:25 AM
RICK269
[quote:5f6b9def8a="blackop555"]The is a sensor that senses the coolant then sends it to a sending unit which in turn sends it to the ECM. Find the one and follow the wires to the other.[/quote:5f6b9def8a]
That's the problem, I can't seem to find the sensor.
Oct 20, 2007 at 8:46 AM
BLACKOP555
  • 10,386 POSTS
should be right bellow the throttle body under the air intake hoses. ill try to find you a diagram online. should be hooked to one of the coolant lines.
Oct 20, 2007 at 1:40 PM
RICK269
Thanks for your help, blackop555. I found the problem. Would you believe ants! Yes, tiny ants! They had gotten into the fuse/relay box and into the relays - 3 of the relays didn't work. I pulled them apart and 2 had ants squashed between the coil contacts, the other one the offending matter fell out when I opened the relay cover. There were ants all through the fuse box. As soon as I had cleaned the relay contacts, they worked again! I HAVE seen this before, in the Northern Territory of Australia. The ants seem to have a liking for small electromagnetic fields!...
Oct 20, 2007 at 4:42 PM
BLACKOP555
  • 10,386 POSTS
nvr would have guessed that one :P i spose they could lik the electromagnetism. lol thats one of the oddest things i ever heard. but glad you got it going :P
Oct 21, 2007 at 12:36 AM
