Coil Testing and specs
HYUNDAI
B679995
Can you tell me if there is a way to test the coils on a
2000 Hyundai Accent, 1.5 SOHC. I have a NEW computer installed and someone else told me NO FIRE at the plugs was likely the Crank Position sensor, so I replaced that also with the same result. I am running out of ideas to try but would surely be BLESSED to have this gas saver going again.
Thank You Very Much
Steven R. Conroy
stoycon@stjoelive.com
Oct 13, 2007 at 6:28 PM
  • 75,988 POSTS
Do below
https://images.2carpros.com/forum/automotive_pictures/12900_2000_Hyundai_coil_testing_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_2000_Hyundai_coil_power_testing_1.jpg
All you got left is the ICM after this.
Oct 13, 2007 at 9:09 PM
