2006 Hyundai Accent Brake Warning Light
HYUNDAI
KALID
2006 Hyundai Accent mileage: 15,000,1493cc. The brake warning lamp flashes from time to time especially when I accelerate.There is no apparent leakage.I suspect the brake oil level which is between maximum and minimum.If it is the case, do I have to add a bit of oil? If so, what kind of brake oil does the Hyundai company use(Dot 3 or Dot 4)?Finally, can't it be the brake pads ?
Apr 7, 2007 at 9:14 AM
  • 75,988 POSTS
[quote:1d4b2d53a6="kalid"]2006 Hyundai Accent mileage: 15,000,1493cc. The brake warning lamp flashes from time to time especially when I accelerate.There is no apparent leakage.I suspect the brake oil level which is between maximum and minimum.If it is the case, do I have to add a bit of oil? If so, what kind of brake oil does the Hyundai company use(Dot 3 or Dot 4)?Finally, can't it be the brake pads ?[/quote:1d4b2d53a6]
Get it fill to the max. with the correct type brake fluid -you sure that lite is not being caused by the emergency brake switch not adjusted properly
Apr 7, 2007 at 11:24 PM
Suggested Repair
Fill the brake fluid to the maximum line with the correct type of brake fluid. Also check whether the parking brake switch is out of adjustment, which can cause the warning light.
Conversation Summary
The owner of a 2006 Hyundai Accent reports that the brake warning lamp flashes intermittently, especially during acceleration. There is no visible leak, and the fluid level is between the minimum and maximum marks. The owner asks whether to add fluid, which DOT type Hyundai uses, and whether worn brake pads could be the cause. The expert advises filling the reservoir to the maximum with the correct brake fluid and checking whether an improperly adjusted emergency brake switch is triggering the light.
