I HAVE A 98 Hyundai Accent 1.5l. On occasion it will not start. Being a manual I can push start it.
When this problem happens the engine will turn over, the starter works & is engaging the flywheel as it should but will not fire. The fix is to push it in Neutral… jump in & pop it into gear then it will start right up. Even if I let the car come to a dead stop after dropping it into gear & not trying to start it on the move, it will fire & run fine.
Anyone have a clue???
Apr 11, 2007 at 5:25 AM
