2006 Hyundai Tiburon / Whiney transmission
2006 HYUNDAI
16,300 MILES • 6 CYL • FWD • MANUAL
BJOEL
Transmission
I own a 2006 Hyundai Tiburon SE with 16,300 miles. I recently noticed after driving with the radio turned down that the gearbox or transmission (not sure) is very whiney. Especially on gears 1,2,3, and 4. Once I hit 5 and 6, it gets a lot softer. It seems to be driving fine, just noisy/whiney.
Could this be the gearbox or manual transaxle? Or, possibly the motor? Although I dont think its the motor because its quiet once I disengage gears. The service light has not come on, and I had the oil change at 14,000.
I am just starting to learn about cars. Any tips you could give would be greatly appreciated.
bjoel
Mar 14, 2008 at 6:04 AM
  • 31,937 POSTS
Hi there,
I would be checking/ changing the transmission oil first, check the drain plug for any metal fragments that could indicate baring failure, (silver grey deposits) noises in these gears and not in 5/6 would indicate lay shaft bearings are your concern, check the oil level first.
Mark (mhpautos)
Mar 28, 2008 at 11:54 PM
