2002 sonata just quit running
2002 HYUNDAI
MANXDUDE
2002 sonata 71,534 miles 4 cyl auto trans
on my way home from work pulling away from a green light it just quit in the intersection it turns over all lights work fine just doesn't start I checked the timing belt it has a few teeth missing but it seems ok not slipping. I know this needs to be replaced but could this cause my problem? also when I turn the key to the on position and listen should I hear the fuel pump? could it be a fuel problem? Help I have lost a day and a half at work because of this.
Oct 4, 2007 at 12:47 AM
  • 75,988 POSTS
Did you hear it? About the belt better do something fast about it could also be the cause-if its an interference engine you asking for big time trouble-major repair. $$$$$$$$
I would worry about the belt than the fuel pump.
Oct 4, 2007 at 3:30 AM
