2002 Hyundai Timing belt spring tensioner
2002 HYUNDAI
SHAWNBOY
Engine problem
2002 Hyundai 4 cyl Wheel Drive Type unknown 97000 miles
I'm trying to replace my timing belt and tensioner. I hit a snag in the process. I'm trying to relieve some tension and remove the pivot bolt on the right of the tensioner. I tried a pry bar and screw driver and tried to lift up the right side of the tensioner to relieve some tension. However, it won't budge at all. I thought maybe if i loosened the other bolt on the right side of the tensioner, it would then be able to adjust the tension. The bolt will not budge at all. I don't want to grind down the thread on the bolt. Breaker bar and serpentine belt tool won't work. I have a 2002 hyundai accent 1.6L. There is a spring underneath the bolt on the left side of the tensioner. Any help is greatly appreciated.
Dec 6, 2007 at 7:26 AM
  • 31,937 POSTS
Hi there,
The tensioner bolt to the lower left is the pivot bolt, back this off. The upper bolt is the adjuster, If very tight, it may have been locked with a thread locking compound. It is a conventional R/H/ thread (turn to the left to undo) Use a good quality spanner (ring, not open end) or single hex socket, make sure that you apply pressure square to the bolt, and it should undo.
Mark (mhpautos) :D
Dec 6, 2007 at 9:16 AM
