1999 Other Hyundai Models Master Cylinder
1999 HYUNDAI
75,000 MILES • 4 CYL • FWD • MANUAL
SANJAY4459
There is a leak in the place where the master cylinder connects to the Car. The oil goes in there but no oil spills below the car. I had replaced the master cylinder but the leak remains. What to do
Sanjay Sapru
Dec 21, 2007 at 6:06 PM
  • 31,937 POSTS
wash down with water, and fill reservoir up. If brakes are working , apply on and off with high pressure a number of times, to try and get fluid leak visable.
re check for fluid loss, check at each wheel as well if fluid is low, and no external leak visable, remove master cylinder and check for leak at rear of cylinder into booster.
Mark (mhpautos)
Dec 30, 2007 at 7:06 PM
