Wash down with water, and fill reservoir up. If brakes are working, apply on and off with high pressure a number of times, to try and get fluid leak visable.
Re check for fluid loss, check at each wheel as well if fluid is low, and no external leak visable, remove master cylinder and check for leak at rear of cylinder into booster.
Mark (mhpautos)
SPONSORED LINKS
Monday, December 31st, 2007 AT 3:06 AM
