1996 Hyunday Accent - broken timing belt
1996 HYUNDAI
JIKOP
My timing belt broke. Is it possible for this 1.5 litre 12 valve engine that in such situation a piston can hit a valve?
If yes, what is the easiest way to find out whether a valve (or piston) has been damaged?
May 12, 2007 at 1:43 AM
TURBOTUFF20G
  • 98 POSTS
yes it is possible to bend those valves,, the best way to check this is by doing a leak down test on the valves with a leak down gaugen other easy ways would be to pull off valve cover and inspect valves, pull spark plugs to check 4 damage and try to look down into cylinders with a pen light, look for marking on pistons from valve contact or other debris
May 27, 2007 at 5:21 PM
