1987 Other Hyundai Models igniter
1987 HYUNDAI
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
RONNOCOMAN
I'm experiencing an intermittant misfire that I can't figure out. New plugs, rotor, dist cap. Timing correct. Coil meets specs. What is the "igniter" in the distributor that my manual refers to? Could it be the source of a misfire that comes and goes? If not, any other suggestions? Thanks!
Kevin
Mar 27, 2008 at 9:04 AM
The ignitor's job is to tell the coil to fire plugs-try checking the engine's compression/injector also the fuel pressure.
Mar 27, 2008 at 11:19 AM
