2004 Hyundai Matrix
ROYFFE
2004 Hyundai Matrix Two Wheel Drive Manual 100000 miles
THE CAR HAS A BNEW BATTERY WHEN YOU TURN THE KEY TO START THERE IS A CLICK BUT IT DOES NOT START. I CAN HEAR A BUZZING SOUND IF I LEAVE THE IN THE ON POSITION
Jan 3, 2009 at 9:45 PM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops
Jan 4, 2009 at 12:51 AM
