1999 Hyundai Lantra Over heating
1999 HYUNDAI LANTRA
K_D87
Engine Cooling problem
1999 Hyundai Lantra 4 cyl Automatic
i have a 1999 hyundai lantra that has been over heating.. no leaks from hoses, have replaced thermostat, have recently had a service done (oil change etc..) have to have the air-con running to stop car from over heating so quickly.. have no ideas on whats happening help please
Aug 12, 2010 at 11:16 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
seems like radiator fan may not be coming on as it should, otherwise the a/c being on would only make the overheating worse. when the a/c is turned on, there is a switch that tells the radiator fan to come on as well. but when the a/c is not on, the radiator fan is turned on by the engine coolant temp. sensor.
Aug 12, 2010 at 11:48 PM
